JStructsteel
- Aug 22, 2002
- 1,448
Framing a floor, what is the better detail for joists bearing on a steel beam? I have a 5.25" flange, so I could split the joists right down the middle, and have equal bearing. I see alot of them overlapping at the bearing, is that for stability, just one row of blocking at the beam?
I do have an issue too where I have a cantilever at the other end, so there maybe some uplift at the bearing. I was going to use a tie down, but wondered if lapping and blocking would eliminate that need.
