SperlingPE
I was asked to look at some floor joists - nominal 2x8'as @ 24" o.c. spanning 12'3". The joists are damaged at one end. The damage extends from the face of the foundation wall inward 5'. The damage is located in the bottom third of the joist. Some of the joists may have damage up further into the joist. There is likely damage at the location where the joist is in contact with the wall (bearing location).
Is it worth trying to design a splice with side plates and through bolts or just go with replacement?
My first inclination was to replace. Add new joists to carry the loads between the existing joists or along side the existing joists.
Whether splicing or replacing, there will be ducts, pipes, and wires that will need to be taken down for the installation work.
