JStructsteel
Do you folks specify exact locations and show blocking/bridging in your plans, or just handle with a note? I was thinking a note, similar to this, unless it was a specific need for exact location.
2.8. PROVIDE WOOD BLOCKING BETWEEN FLOOR AND ROOF JOISTS @ BEARING LOCATIONS IF BOTTOM BEARING. IF SPAN OF ROOF OR FLOOR JOIST EXCEEDS 8'-0" PROVIDE MIDPOINT BLOCKING OR BRACING IN EACH JOIST SPACE. FOLLOW LOCATIONS CALLED OUT ON PLANS IN LIEU OF THIS REQUIREMENT
houses are built all the time, how into the weeds do you get?
