FLOOPS help
balutan
I am new to this simulation software. Any help will be appreciated.
It keep giving me the following msg when I try to run floops. Anyone know why?
DATEX: No materials and variales found.
The material name "Default" was not found in DATEX !
Have you consulted the manual? Have you run the example files?
TTFN
In the UNIX console, basically I just type
%floops floops_fps.cmd
which floops_fps.cmd is the example file comes with the program.
But it doesn't matter, even without the filemame, it still gave me the same error msg as I mentioned before.
What is the error message? You need to provide a LOT more information if you expect help!
