gte447f
- Dec 1, 2008
- 816
For a floating slab on grade, what is best practice at an exterior door? I assume the slab edge should get extended to the outside face of the wall. Does the slab edge need to be thickened? If so, how much, or should it be turned down onto the strip footing/grade beam? It seems to me that if the slab is isolated from the footing/exterior wall at the typical perimeter section, then it should remain isolated from the strip footing at an exterior door? Do others agree or disagree? This is in an area where frost heave is not a big concern (frost depth typically 12" by code, but probably actually less than that). The slab is 5" thick. The strip footing is 1'-4" thick x 2'-6" wide and is 1'-4" below slab.
See attached sketch of basic alternatives that I am thinking about.
