TexasGeotech
Geotechnical
Have any geotechs or structurals that frequent this forum ever used a floating slab (ground-supported slab) for the bottom slab of a building with below-grade levels (e.g. a parking garage) with expansive clay subgrade soils? Just want to know if it is practical and desirable. For example a 2-level below-grade parking garage with clay and clay-shale 50 feet deep. The ground-supported slab and vertical height considerations could accomodate several inches of heave, no? The clays are deep enough to not be affected by near surface moisture fluctuations outside the building footprint, and at depth the only water source would be thin seams of flaggy shaley limestone with groundwater, within the clay-shale formation, so to account for some possible heave, i want to be able to suggest a ground-supported floating slab and not a more expensive structurally supported slab (on the pier foundation elements). Any comments are appreciated.
The building would be water-tight i imagine, and any water infiltration along thin backfill zone behind basement walls will be collected by a drain and sump pump system.
