we have floater valves with all different sizes from 2'' to 10'',different classes from 150 to 2500.
now the body-cap material is casting WCB or LCC.
we have a problem since long time.
we found lots of valves leak during Low pressure testing.
almost all leaks are from body-cap joint.
how i can check compression for gasket.
because i doubted that leaks is due to either gasket improper compression or stud tight .
