I am trying to figure out the horizontal distance that a water jets out off a steep channel. The channel ends at edge of a cliff. The objective is to determine the horizontal distance the flow will travel before it impacts the ground (which is 16' below).
Basically, the structure involves a steep (s=0.4) 2.5' width rectangular channel which ends in a 2' long horizontal section. A 5.5' radius is applied to the transition. Design flow is 10.6 cfs. I've attached a sketch.
Doing my research, it seems that the 2' long horizontal section may be too short to generate a hydraulic jump. Plus, a hydraulic jump is not desirable.
This may not fit a flip-bucket scenario since there is no bucket lip. (EM 1110-2-1603). The lip is not desirable because of standing water issue.
Is there any method out there that I can use to approximate a solution?
Appreciate the help.
Saurabh
Saurabh
