11 million gallons per day is the mean usage rate. The peak usage rate is between 14 and 16 MGD, depending on which report you trust.
The Contract is shown. This is a take or pay contract. That means you buy 18 million gallons every day whether you use or don't use it. You do not pay for what you use, you pay for 18 million gallons every day.
11 million gallons per day is the mean usage rate over a year. Some days are higher and some lower.
Incorrect. The 72-inch GLWA supply will continue to operate at minimum until 2046. Almont (30 year contract began July 1 '15) Imlay City (30 year contract takes effect June 2016) and Lapeer (30 year contract proposed and pending) are all fed by the 72-inch line from the Imlay pumping station. There are also multiple municipalities to the west of Flint (Swartz Creek, Owosso, many others) who will continue to receive their water from that 72 inch main. Meaning that the GLWA line running through Flint will not be taken out of service.
The velocity must be maintained in the 72-Inch water pipeline. Otherwise, the disinfectant residual will be used up. When water is stagnant, you run into water quality problems such as stale water. You will also have pumping problems as the pumps are probably designed to operate at a higher rate. It will be difficult to operate the pipeline at low volume. Sediment will also drop out at low velocities. The authority will probably cancel the contract as it is not economical to operate in that manner.
If you read all of the articles you linked to completion, instead of just stopping when you found something you liked, you would have found this, from the same article:
"companies typically select locations based on factors such as workforce, proximity to markets, and access to qualified suppliers"
Sound familiar? Like what I just said? I guess you're not the only one who can quote out of context to support an argument.
There you go again, quoting of context. You left the first sentence out of the paragraph:
"The bigger issue is that incentives do little to alter the locational calculus of most companies. The broad body of evidence on incentives, including the Times series, finds that incentives do not actually cause companies to choose certain locations over others. Rather, companies typically select locations based on factors such as workforce, proximity to markets, and access to qualified suppliers, and then pit jurisdictions against one another to extract tax benefits and other incentives."
It is important to be able to discern the difference between a belief, a fact and an opinion.
