Flexible Tension spring
  • Thread starter Thread starter prasad9400
  • Start date Start date
P
prasad9400
Guest
Dear all,
Here is thesimplewayfor making "flexible tension spring" in proe wf
and here is the part file 2011-01-08_034138_Tension_Spring.zip(WF4)
Enjoy
Prasad
Thanks a lot man
ill add that to my collection of springs for design engine students
In SPRING.PRT the Relations for Var Sect Sweep 1 you use :
sd8=30+350*trajpar*6
Why do you use 350 instead of 360? Was it to get the correct amount of rotation to connect the hooks to the main body?
yes
you're right
Prasad,
can u please upload the spring part file to open in WF-
3????
cause since im using WF-3 the uploaded part did not open.
if anybody can please upload a spring in WF-3 format using
trajpar option.
kenigma said:
Prasad,
3????
trajpar option.
I have uploaded a tutorial that describes how to make a flexible spring. Dont think that was so long ago i uploaded it (for the second time) .
Try to do a search for "flexible spring"
//Tobias
Thanks a lot~it's great !!
