Jan 8, 2011 #1 P prasad9400 Guest Dear all, Here is thesimplewayfor making "flexible tension spring" in proe wf View attachment 4872 View attachment 4873 and here is the part file 2011-01-08_034138_Tension_Spring.zip(WF4) Enjoy Regards Prasad
Jan 9, 2011 Thread starter #3 D design-engine Guest ill add that to my collection of springs for design engine students
Jan 11, 2011 Thread starter #4 J jsantangelo Guest In SPRING.PRT the Relations for Var Sect Sweep 1 you use : sd8=30+350*trajpar*6 Why do you use 350 instead of 360? Was it to get the correct amount of rotation to connect the hooks to the main body?
Jan 17, 2011 Thread starter #7 K kenigma Guest Prasad, can u please upload the spring part file to open in WF- 3???? cause since im using WF-3 the uploaded part did not open. if anybody can please upload a spring in WF-3 format using trajpar option.
Jan 19, 2011 Thread starter #8 T tobbo Guest kenigma said: Prasad, can u please upload the spring part file to open in WF- 3???? cause since im using WF-3 the uploaded part did not open. if anybody can please upload a spring in WF-3 format using trajpar option. Click to expand... I have uploaded a tutorial that describes how to make a flexible spring. Dont think that was so long ago i uploaded it (for the second time) . Try to do a search for "flexible spring" //Tobias
Jan 19, 2011 Thread starter #9 T tobbo Guest Found the thread for you. [url]http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=41 758&PN=3[/url] //Tobias
