beretta24
- Feb 4, 2006
- 19
I'm workig on a lubrication system and have to connect the tank to a manifold with a flexible connection. The connection or joint needs to withstand about a half inch of travel in any direction. Currently, the connection points are 3" ANSI B16.5 flanges.
The line/connection needs to include an elbow. The kicker is the tank flange is located about 11" to the side and 7" below the manifold (at a right angle to each other). Oh, the other kicker this is a military project and the joint must withstand about 15g and 5g of shock in the vertical and horizontal directions respectively for this application. Thanks for any help you can give.
Brian
Brian
