kandula1, Compress obviously does not know that virtually all spiral wound gaskets will be fitted with at least an outer solid metal ring that acts as a compression stop. For your pressure I would specify an innner ring as well. Besides serving as a compression stop these rings prevent the gasket from squirming or collapsing to the inside and from unwinding during handling.
I would use only a metallic gasket. You might also look at a "Kammprofile" style gasket, consisting of a grooved metal core with a soft facing. A solid metal gasket is also an option but will take a lot of bolting to seat it.
Contact Flexitallic, Garlock, Klinger or any of the manufacturers, they all sell the same stuff.
Mike
