Flex Duct Pressure Losses
Webber
CA
Does anyone know of a good site calculator to determine static pressure losses in flexible duct?
Here is a good rule of thumb: use straight piping charts Delta P vs. flow rate and double the Delta P (pressure loss) for the same flow rate. You will be on target but if you have any doubt check with flex ducts manufacturers as they all provide these charts free of charge right on line.
