Hammer335i
I am looking at flattening the end of a tube for an easier mechanical connection, but I want to make sure the resulting shape is strong enough to handle the applied design loads. I can make the part in Autodesk Inventor and run it through the program's FEA application, but with my limited knowledge of FEA, I am not 100% sure how to analyze the results.
From what I know, I should be looking at the Von Mises Stress, Safety Factor, and Displacement.
Von Mises: I am looking a these stresses and comparing them with the yield stresses of the material (in my case 50 KSI). So long as these stresses are less than the yield stresses, I am okay, correct?
Safety Factor: I am looking at these values to see how many times the applied force can be applied before it fails. I assume I want to keep this at 2 and above?
Displacement: The part should have minimal displacement, as determined by my system's requirements.
Are my assumptions correct? Is there anything else I need to be looking at?
Thanks,
Paul
Thanks,
Paul
