flat surfaces on a sphere
MackDiesel
Aerospace
Jul 29, 2010
6
Having problems placing 2X2 squares on a spherical object and making them normal to surface..can anyone help...Thanks
I have an 18 inch radius and trying to fit as many as I can on a 1/4 sphere...90 degrees.... a set of 2x2 light PCB Boards..
The general tiling of a sphere is very hard and I don't know there is a perfect solution to what you want.
A general solution might to pick one of the spherical polyhedrons (e.g a soccer ball with pentagons) and work from there.
As for getting at least one normal, you can create a sphere (or part of one) create a plane tangent to its surface, and sketch a square on that. After that, it probably depends on the pattern you want to create. Maybe someone else has some ideas?
BTW, you might Google "Tiling a sphere" There is lots of discussion out there on this. Or look here for some images:
Mark
Thanks..... I am investigating the use of the wrap sketch function...
