This is a legacy design made from galvanised spring steel, they were always made to a material spec of BS5216, minimum tensile strength 2500 N/mm2
The supplier is now unable to get this material and we've had samples in different new materials but they all take on a compression set, see the attached pdf for how the spring fits into the assembly.
Any thoughts on a better material to use which will still close the shutter, but does not get overstressed in this application? I have tried a similar design as a torsion spring but the thin (0.25mm) wire diameter means that long arm buckles before bending and a thicker (0.35mm) wire just takes on a permanent set again. It's possible that an extra turn on the torsion spring's coil would help (the trial part had only one active coil) but there's still the problem of the end dropping out of the shutter's slot and jamming up.
I don't have much space to go with a redesign, as you can see the shutter goes almost all the way up giving little space for the spring.
Thanks for any help you can give, I've been staring at this for too long and I've got the Engineer's equivalent of writer's block!
