ok, i agree, but since u will check ur slab against earthquake (punshing stress + vertical earthquake), do i have to check it for something else (other than gravity loads of course) ??
Thanks for ur help.
2nd question :
I dont know if u're familiar with etabs, when u assign stiffness modifier to a shear wall, i generally assign 0.7 to f11, f22, f12 (axial rigidity). The question is : do i use these stiffness to have the reinforcement also or just to check the drift ?? i mean, i was intending to put the modifiers for the slabs and beams and 1.0 for walls. It will make it the wall more dtiff and the reinforcement will be more than if u put 0.7.
What do u think ??
thanks for ur help
