stan45
- Sep 23, 2009
- 18
I am currently working on a analysis of an aluminum structure that consistes of verical and horizontal aluminum tubes. & 1/8" thk. aluminum plates with 3/4" sq. holes at 1" c/c that are fastened to these tubes to create a screen wall. The structure is specified to resist a 100 lb point load distributed over a 1 sq. ft area per the elevator code. This is a elevator screen wall. The structure must meet a maximum deflection of 1" under this loading condition. I do not have access to finite elemnent analysis software. Is there any way to analize this otherwise? I was think of using Roark's equations but one of the stipulations is that the plate must be of uniform thickness. Since the plate has holes in it I am not sure how or if the equations can be modified.
