vennivivi
- Jan 15, 2007
- 45
Help forum forum members ! We are having intermittent phase to phase fault on a distribution panel @ 590 V. We could see trace of arcing between the phases on the incoming circuit breaker feeding the common bus in the panel. The circuit breaker was replaced. Before energising, the installation was checked for short circuit and ground fault.The installation was powered and after some couple of hours,the main breaker tripped and arcing was again seen between phases. This installation, as it is now, was operating well before.
I understand that phase to phase fault is common if dirt or moisture is present between the phase but this is not the case.
Any advice welcome.
Grundig
Any advice welcome.
Grundig
