I want to use an automatic blowdown system and use it's waste energy, in a boiler that produces 6.400 kg/h at 10 barg. A typical use for this kind of situations as it is showed in the image that i've attached.
My question is if the boiler feed water tank is atmospheric what is the pressure in my flash tank and that i need to perform my energy recovery calculations?
And what if i want it to generate steam at a controled pressure (for example 3 bar)? How can this be done?
Thanks!
Thanks!
