Our facility operates several flares, which are subject to the pilot monitoring requirements of 40 CFR 60.18(f)(2). Our delema is that we chose to use ionization detection to indicate flame presence. This system is either off (0) when in normal operation or on (1) when in an alarm state. The problem is that we are constantly having problems with the indication swinging from 0 to 1 within a span of minutes (this is continuously monitored on the DCS) so that we generate records of non-compliance. In reality the pilots are lit as evidenced by the fact that reignition is not necessary.
The instrument department can't find anything significant to fix (or so they say). As a consequence, we continually write work orders to have them sent back saying nothing abnormal was noted.
My question is, does anyone know of another technology that is more reliable other than thermocouples, IR, and UV? Our experience with TCs is better than IR or UV, but we still burn the wires off from time to time. We have tried IR, but have the same problem as the ionization detection. We are currently experimenting with UV, but getting similar results. I'm in a quandary???
To muck the situation even more we expect issuance of our Title V Permit shortly which will require deviation reports. Currently we are having literally hundreds of deviations per month.
Thanks in advance for the help.
John
John
