engahmedbahgat
Hello all,
I have a strange case, please help me with:
I received a new equipment (gas turbine meter) with flanges connection, but the holes of the flanges are threaded ??
and the flange welded to the pipe is a normal ansi flange (b16.5), so when installing the turbine-meter, the bolt suppose to be connected with the pipe flange with nuts as usual, and connecting with equipment flange(flange with threaded holes) without nut because both bolt and flange holes are threaded
is that a standard piping connection way in a high pressure gas (about 20 barg) ??
thank you in advance
