Unless you have a moment connection at the beam support/connection, then you only have tension in the top flange, tension in the top half of the web, and compression everywhere else (well, that's a simplified version...actually a bit more complicated, but not significant for this case). Then you have the shear in the connection, which will likely prevail.
Given that, design your weld for those conditions. Don't forget to combine the conditions for a compatibility check.
