A pressure vessel has a 16" Nom. Sch 80 pipe attached (welded) to it , the length of pipe is 2 feet. At the end of pipe a slip on flange is to be welded and to be covered by a blind flange.
From where shall i calculate the desired thickness of flange, bolt size & bolt pitch circle dia. The vessel is of ASME Section III Class NB.
