To install lug body butterfly valves, safest and best way is to use studs and nuts. Studs ensure you get the maximum possible thread engagement. The length tolerance on machine bolts can lead to low thread engagement which can lead to stripped threads in the body when bolt is exuberantly tightened. Or, just as bad, can lead to bottoming out in the hole preventing full compression of the gasket. Always go with studs and nuts.
