PP007
- Apr 13, 2010
- 19
In our plant there is Ethylene dryer to remove the moisture & after bed exhaust it required to do regeneration..High temp N2 pass through it & vessel & piping under go from atm temp to 330 degree centigrade temp.
After regeneration several times found that one or two flange get leak while taking the service in line.
Hot bolting is method but there is high risk. is there any way which can solve the problem leaking after regeneration.
Note we are using correct bolt , Correct Graphite filled gasket & proper tightening also .. still facing problem
awaiting for swift response.
