splanti,
True, but in the initial assembly make-up, bolt loads are calculated to provide the necessary loading required to achieve leak-free operation at the full range of temperatures/pressure/external loads. Too often, designers fail to realize that the ASME allowable stresses in bolting materials are mis-interpreted. The design allowable temperatures contained therein are based on bolt stresses at 25% of the Ys of the bolting materials, not the actual bolt stresses applied to individual bolted joints. These stresses are commonly in the 45% to 65% Ys range, and even as high as 90% in some instances. In most cases, I have cautioned that typical high temperture bolting be limited as follows: B7 @ 400 Deg. F, B16 @ 600 Deg. F, changing to higher strength materials above that.
The flange assembly, including bolts, seals, and the flanges themselves must have sufficient preload capability to withstand all of the design conditions. In many cases of thermal transients or external loads, additional bolt loads my be required. This is the reason that a one-load-fits-all approach often fails. The responsible engineer must account for all of these conditions before approving the specific assembly procedures for such flanged joints.
As for the hub/clamp connections, if the joints are API style with BX or RX ring gaskets, these joints are extremely prone to problems if there is any excessive side loads or thermal shocks. The gaskets are not designed to accomodate any movement in the joint due to these elements. These gaskets are plastically deformed in a specific ring groove on initial make-up, and will not relialby reseat themselves if movement from thermal or external loads occurs. The other similar connections, the 'Grayloc' style from Oceaneering and LTS Energy, can and do accept such movement and are leak proof in most cases. There are 'quick release' designs available to suit most applications for topsides, subsea, and petrochemical applications.
This same seal is used by most of these specialty manufacturers in a what is commonly called a 'Compact Flange'. These designs are currently in use in larger sizes - up to 42" - and pressures - up to 30K psi for ASME and API applications.
