Thank you r6155.
Wm1(if governs), with Hydro-static test pressure (1.3 x Design pressure) will be higher than with Design pressure, and so the Bolting Torque. During the Hydro test is it not necessary to tighten the Flange Bolts to Torque with Hydro-static test consideration?
