When flammability limits for, for example, acetic acid, are published, they are, as usual, quoted as % v/v. I assume that the v/v approach is used because it is dilution which limits flammability by failing to sustain burning, rather than something based upon stoichiometric considerations.
I have been trying to calculate whether vapours in equilibrium with mixtures containing acetic acid are flammable.
My start point has been:
(i) LFL for acetic acid/air is ~4 % v/v.
(ii) Flashpoint of acetic acid is 39 deg. C.
I take pure acetic acid at 39 deg. C, and then calculate the composition of acectic acid/ air in equilibrium. This gives me 7.87 % v/v acetic acid in air. I assume that this is higher than ~4 %v/v because, although the VLE method is fairly sophisticated, it is based upon vapour pressure, which is a liquid property.
Independently, I calculate that the average molecular weight of associated and non-associated acetic acid species in vapour at 30 deg. C is 107.8.
I take the results of my first calculation (7.87% v/v unassociated acetic acid, etc.) and change into mass units. I then change again into volume units using the higher molecular weight of 107.8, which gives me a figure of 4.5% v/v acetic acid species in air. This is not far away from the 4 %v/v LFL.
Is this approach correct? Is the similarity of 4% and 4.5% more than coincidence? Is there a simpler way of doung this calculation? Can anybody confirm that, for acetic acid, the published figures for acetic acid refer to the % volume of associated and non-associated species?
This is not homework. If it were I would change courses.
