Hey Guys,
1. I've been hearing this for along time. If the motor for example has 93FLA nameplated on it but it also has 1.15 service factor does that mean that the 93 x 1.15 = 106.95 available amps and if so why don't they just nameplate it for that?
2. I think it has something to do with the insulation or temperature rise? I'm sure you'll correct me if I'm wrong. Does it mean that you have a Class F rise @ 93 FLA and Class B rise at 106.95 amps.
Now these are things I've heard for many years so I want to get this right once and for all.
3. I've seen other's take the motor nameplate horsepower example a 75HP x 1.15 = 86.25 HP. Is this correct?
4. One last issue. If the motor is rated at 460V and you input lets say 480V. I know more voltage means less amps. But can you get in trouble with the misconception of available amps? Can you overheat at the higher voltage? Or am I just overly concerned?
5. Let's say this motor is sized for a condition that is 73 NBHP or very little wiggle room for system error. Any psi swings could be deteramental.
6. Another issue I have considered is the ambient temperature and the affects the motor overheating possibilities so I will hold off on that until I find out if some answers to the above.
Wayne E. Lovison
service-parts@naglepumps.com
Wayne E. Lovison
