Fixture for mounting lens
Bayeng
I am running into a problem on assembly line of a product which involves gluing a triangular shaped prism on a metal surface using an adhesive. The challenge is to make a fixture so that the prism could be mounted flat against the metal surfaces.
Thank you for any suggestions.
Suggestions on....? Without you specifying what the exact problem you're encountering is, we can't really make a suggestion of any worth.
Dan - Owner
