Hello all,
I have been asked to design a replacement waste heat boiler to ASME VIII-1 where the ends act as tubesheets and somewhat vice versa.
Probably this could illustrate things a bit better:
I've also drawn a sketch (attached to this post) to illustrate the problem a bit better.
The tubes are not located in the central portion of the tubesheets but are rather located eccentrically in the lower section.
The remaining top section of the tubesheets is supported additionally by few 'S'-shape stays made from solid bar which are welded to the shell.
Are you aware of a provision in ASME VIII-1 that will allow to take this eccentricity into account
or the standard UHX method (where I believe the assumption is "tube OTL is concentric to the tubesheet OD") will be sufficient?
I would appreciate any help if someone has had this scenario before and could share a few thoughts on how to approach it safely.
It is the first time I encounter such design.
Many thanks!
Many thanks!
