I am in Quality, working with Catia V5. Is there a way, either within V5 or with outside vendor add on software, to create first article inspection FAI sheets automatically? What I am looking to do is take a drawing, assign each dimension, note, etc a ballooned number on the dwg, and compile these in a data table (ideally in AS9102 format). I really want this to be nearly automatic, where I just push the "FAI" button and all this work is completed.
Any ideas or suggestions are appreciated.
