firetube,steam boiler,designing software?
  • Thread starter Thread starter -
  • Start date Start date
Guest
Dear sirs:
we searched for a software that help to engineer for designing professional high efficiency firetube boilers, but couldn’t find anything unless; that isn’t our choice.
So , do you have information about the designing professional fire tube steam boiler software?
Thanks with
Best regards
rousta,
What are "professional" fire tube boilers ? How are they any different from regular, ordinary fire tube boilers ?
Most people are not starting new companies to design boilers..... so I would suppose that there would be a limited market for such software.....
Some people offer software that would "RATE " an existing boiler's performance. This may be what you are looking for...
MJC
See if you can obtain a copy of Australian standards AS1797 design of fire tube boilers. The appendix section for tube sheet temperature calculations gives excellent references on literature refereeing to fire tube boiler design. Alternativly i could scan the page and emial it to you.
I am also looking for design information on firetube heaters. Not necessarily firetube boilers, but what are normally called indirect fired heaters. These use a firetube to heat water or glycol. A coil is suspended in the water or glycol and a second fluid is heated in the coil. I am chiefly looking for software but just any info on how to design the heater would help. API has a specification on it, 12K I believe, but it doesn't go into much detail on how to calculate the heat transfer.
