Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
waein said:Hi
The contract documents mostly here in saudi specifies NFPA,IBC.
Regarding the water storage tank for the fire protection system,in my view it should be combined with potable water tank and the suction of the potable water pump and fire protection pumps (both) should be from the bottom of the tank. The potable water pumps should be controlled via sensors mounted inside the tank at elevated levels (high level and low level) to stop the potable water from draining the whole tank and ensuring that a level of water below the low level sensor is always available and as such it will ensure that calculated amount of water is always available for the fire protection pumps i.e the water that is below the low level sensor.The advantage are as follows:
(A)If a separate water tank is maintained for fire protection the water quality keeps on getting degraded more so since the eventuality of fire breaking out in buildings is remote even on fifty years basis.This is quite a concern in area that have to maintain a water storage for FP system i.e no water mains supply available specially in middle east
(B)The cost of constructing single tank with combined volume will be lower than considering two independent tanks.
(C)The water quality in the tank is ensured by continuos flow of water from the tank i.e no stagnant water
(D) if the more obvious solution is sought i.e the potable water pumps suction from higher level and fire protection pumps from lower level this would create a stagnant volume of water below the suction of the potable water pumps. This stagnant volume of water would eventually get degraded and would be a constant source of pollution to the upper level water which is constant use for potable purposes.
The above design affords in my opinion best convergence of design simplicity + cost + Integrity + technology.
OVER TO HONOURABLE MEMBERS FOR DISSECTION AND CRITICISM.[/b]
