jon.torres89dtx
Industrial
Howdy to all,
I have been in fire protection for about 8 years.S Started out as a helper and moved my way up to becoming entry level designer. I just would like some explanation on SPRINKLER SYSTEM DEMAND for calculations.
I just would like an easy explanation, if there is one ,of what the flow required and pressure required (EX: 310.772gpm @ 32.924psi) is meaning, also what the flow of heads means when i see it in my calculations EX: Actual Flow and Required Flow, and what the safety factor means. I am good on layout rules, its just calc's are getting me a little stumped since i am going to start digging into them more to get me started. Like my past foreman taught me it meant something like you have to have so much water to flow so much but just needed some refreshing on it, thanks!
