Fire Flow Req'd Volume per NFPA based on occupancy
efejr28
Good day. I need to determine the Fire Flow Storage Volume required for a Health Care facility per NFPA based on occupancy. Should I look into NFPA Codes 22 & 99?
In which cases is the NFPA applicable? Why not use the IBC or other?
Thank you,
None of your referenced standards and codes will tell you fire flow. See Appendix B of the International Fire Code or NFPA 1.
