FIRE FIGHTIING DESIGN
SHAHUL456
AE
Hi All,
As per the NFPA standards let me know the following,
*water demand for firefighting for class A, B ,C, D fire
*pump selection -(operating pressure,head and flow rate)
Basically, the question can be covered by the various NPFA Standards. You may need a Fire Protection Engineer to help you to determine the required water rates and fire water pump design for the process plants based on the Codes.
It helps if the question can be focused to more specific.
Shahul456,
Fire design needs experience. If you are new, you are most likely to mess up. Take the cue given by mk3233,
GDD
Canada
