Fire truck pump can have a negative inlet pressure, since it can take water in a lake with a water level below the pump.
Some literature I read state that it is different when the pump is connected to a hydrant with hoses, and that the pump inlet pressure should not be lower than the positive pressure of 20 psig.
Could you direct me to an article or a book that would explain the technical reason behind this recommandation ?
Thank you in advance for your help.
