deluxeparty
Hi everyone.
I am currently working to replace a mechanical quality testing-simulator with a hydraulic unit. I have little expertise in this area, but we are trying to keep it in-house as much as possible, so I am hoping you can help me out a little bit. I am currently trying to find appropriate dimensions for the hydraulic unit.
The goal is to get two adjustable resistance peaks against a pneumatic force in one stroke, this resistance will be between 400 and 1400N. So I have come up with an idea in which we use a hydraulic cylinder acting as a pump into a reservoir. The piston will be driven by an external pneumatic force, and it is upon the piston that the resistive force will act. To get the resistance, I have decided to use a pipe at either end going to an on-off valve. To get the adjustable peaks, I want to use an adjustable restrictor valve on each side that will limit the flow thereby increasing the pressure in the cylinder/pipe when the on-off valve is closed. The restrictor size will determine what force peaks we can achieve.
My query is what sort of formulae to use to find the appropriate restrictor diameter? I am making an Excel spreadsheet in which I can input different values for the piston size and stroke, stroke time, pipe diameter, fluid density, etc. whereupon it will output the flow, fluid velocity, etc.
Most resources I have found seem to discuss pressure drop. What I want is pressure buildup, but I suppose it's the same thing? I have been pondering this for a few days now and I have found a few formulae online and in books that never give the same results. Color me confused!!
One of the first online resources I happened upon was this thread, and I downloaded the spreadsheet collection posted by hydroman247 (thank you for that by the way!):
Using this gave me some nice figures but I don't trust it because I don't fully understand how it uses the inputs!
I hope I have explained my question properly and that you can help!
Cheers!
Cheers!
