I used to lug heavy Tek scopes around. Then, there were Fluke and TEK battery scopes with LCD. Very good. A lot better than the old ones. Then, there came Pico Technology with their Picoscopes and TiePie with their HSx units. Both companies only have USB data acquisition units that use the PC for HID and storage. My eperience is that the Picoscope is rather sensitive to short transient overvoltages (have already destroyed two 200 Mz units that both my LeCroy and TiePies survive).
The TiePie is my favourite. Four channels, 12 bit resolution is adequate for most work. The software is great. You can build filters and mathematical expressions using drag and drop right on the screen. Very good triggering and easy to set.
What limits the TiePie units is that they do not have the fastest sampling rate. At 50 MSa/s, I miss some of the details I can see with the LeCroy and the PicoScope.
There is another limitation with most USB units; they do not have the same sensitivity as you get with dedicated oscilloscopes. There may also be DC level issues.
Then, there are lots and lots of other USB units at low cost. Cost is so low that one could order a few different and see if they fill the bill.
Gunnar Englund
100 % recycled posting: Electrons, ideas, finger-tips have been used over and over again...
