Find element number in mesh module
marenkr
Marine/Ocean
NO
Hi!
If I find an error in an element in the visualisation model, how can I find the same element in the mesh module so that I can fix it?
If this is not possible, how to fix an excessive rotated element?
Hope someone can help me!
In the visualisation module you can use the display manager and the element set that gave you the error will be listed. Highlight it and you can see it there.
corus
Thanks,
When I highlight the elements in visualization mode I find the element number. Can I then go back to the mesh module and find the element there?
If it's a single part you're ok but multiple parts are numbered as per the part. I believe that you have to print out the element numbers in the .dat file to convert them from the part numbering to a global numbering, but how I'm not sure, sorry. Personally I just view the elements in the visualisation module and relate that element position back to the mesh in CAE. Usually the problem of excessive deformation/rotation relates back to either a problem in contact/adjusting nodal positions, bad meshing with quadrilateral/tet elements or just excessive distortion with plasticity.
corus
I seem to remember that element nos. get changed and are not the same.
Gurmeet
