Find Components and change color automatically 1
OlafU
Automotive
Jan 31, 2012
19
Hello all.
I´m looking for a way, to Change the Color of components automatically. My idea is, to run through an assembly structure, search for a certain component name and change the color of this component to a defined color. I tried it with some bits and pieces from other scripts, I´m able to find the components in the assembly structure and highlight them. But I´m not able to select the components, neither to modify the Color of the components.
I created a small example assembly with the components Yellow, Green, Blue
Here is my script for this simple example:
'Search for Components, Highlight Components, Modify Coloring
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports System.IO
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpen.UF
Imports NXOpen.Utilities
Module ListStructureOnlyComponents
Dim s As Session = Session.GetSession()
Dim lw As ListingWindow = s.ListingWindow
Dim ufs As UFSession = UFSession.GetUFSession()
Dim theComps As New List(Of Assemblies.Component)
Sub Main()
Dim dp As Part = s.Parts.Display
Try
Dim c As Component = dp.ComponentAssembly.RootComponent
WalkAssemblyTree(c, "")
Catch e As Exception
End Try
End Sub
Sub Echo(ByVal output As String)
s.ListingWindow.Open()
s.ListingWindow.WriteLine(output)
s.LogFile.WriteLine(output)
End Sub
Sub WalkAssemblyTree(ByVal c As Component, ByVal indent As String)
Dim children As Component() = c.GetChildren()
Dim newIndent As String
Dim loadStatus1 As UFPart.LoadStatus = Nothing
Dim displayModification1 As DisplayModification
For Each child As Component In children
If indent.Length = 0 Then
newIndent = " "
Else
newIndent = indent & " "
End If
Dim theInst As NXOpen.Tag = ufs.Assem.AskInstOfPartOcc(child.Tag)
Try
If child.DisplayName.Contains("Yellow") Then
Echo ("Yellow found")
'Dim my_select As SelectionHandle = TransientObject()
'Selection.AddToTaggedObjectsSelectionList(my_select, child,True)
child.Highlight ()
displayModification1 = s.DisplayManager.NewDisplayModification()
displayModification1.NewColor = 6 'Color Yellow
displayModification1.Dispose()
End If
If child.DisplayName.Contains("Green") Then
Echo ("Green found")
child.Highlight ()
displayModification1.NewColor = 36 'Color Green
End If
If child.DisplayName.Contains("Blue") Then
Echo ("Blue found")
child.Highlight ()
displayModification1.NewColor = 211 'Color Blue
End If
Catch ex As Exception
Echo("Exception: " & ex.Message())
End Try
WalkAssemblyTree(child, newIndent)
Next
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
End Function
End Module
Is there a way to to solve this issue?
Thanks in advance
NX11.0.0
Hi Olaf,
Please use the code option when placing bits of code...
Makes it easier for us to read...
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Hello Ronald.
Thanks for hint.
Here is the code again:
Code:
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
    Sub Main()
        Try
        End Try
    End Sub
    End Sub
                newIndent = " "
            Else
            End If
            Try
                    child.Highlight ()
                End If
                    child.Highlight ()
                End If
                    Echo ("Blue found")
                    child.Highlight ()
                End If
            End Try
        Next
    End Sub
    End Function
End Module
Thanks in advance
Olaf
NX11.0.0
This should probably do it if you only want to change the color of the component instance
Code:
Dim theComponent(0) As DisplayableOjbect = CType(child, DisplayAbleObject)
displayModification1.ApplyToAllFaces = True
displayModification1.ApplyToOwningParts = False
displayModification1.Apply(theComponent)
But if this is only for status information / inspection then i would suggest you use HD3D Visual Reporting which is easy to setup and use.
Hello petulf.
Thanks for the reply.
I tried it, but I received an error message: "Explicit initialization is not permitted for Arrays declared with ecplicit bounds."
Olaf
NX11.0.0
Yeah the array declaration was messed up, see the corrected code in the form of a sub procedure
Code:
    Sub changeComponentColor(ByRef theComponent As Assemblies.Component, ByVal colorId As Integer)
        Try
            Dim theDisplayObject() As DisplayableObject = {CType(theComponent, DisplayableObject)}
            Dim displayModification1 As DisplayModification = S.DisplayManager.NewDisplayModification()
            displayModification1.NewColor = colorId
            displayModification1.Apply(theDisplayObject)
        End Try
    End Sub
you could then write
Code:
    changeComponentColor(child, 36)
End If
Hello petulf
Thanx very much, it works perfectly!
Olaf
NX11.0.0
In summary the code look now like this:
Code:
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
    Sub Main()
        Try
        End Try
    End Sub
        Try
        End Try
    End Sub
                newIndent = " "
            Else
            End If
            Try
                End If
                    changeComponentColor(child, 6)
                End If
                    changeComponentColor(child, 211)
                End If
            End Try
        Next
    End Sub
    End Function
End Module
Olaf
NX11.0.0
