Fillets - Auto Select Fly-Out Menu 1
MDGroup
Somehow I toggled off a setting, and cannot figure out where it is to toggle it back on.
The Fillet Command used to work like this:
After I selected the first edge, a fly-out menu would pop up at my cursor, with the option to select similar edges (all connected, all internal edges, …)
This was really helpful when you had a pattern, or lots of ribs, or something like that where you had 20-30 or more similar edges to select. Instead of selecting each one individually, you had the option to automatically select groups of edges.
Somehow I toggled that feature off, and now have to select each edge one at a time.
Anyone know where that setting is?
-Lou
I am running SW2020, but this feature was available at least in 2019 and maybe before that.
I think what you are looking for is here:.
View\Toolbars\Customize
Scott Baugh, CSWP [pc2]
CAD Systems Manager
Evapar
"If it's not broke, Don't fix it!"
faq731-376
Since you are running 2020, if it is not there contact your support could be a bug in SP0.0.
Thanks for being a guinea pig for the rest of us ;)
CAD Systems Manager
Evapar
faq731-376
Thanks for the response. I finally did find it.
There is a check-box when you open up the Fillet Command (Where the Feature Tree is). Check 'Show Selection Toolbar'
-Lou
