Hi everyone,
When I use the toolbar to select the fillet command and then try to fillet the corner of a 3D solid model in AutoCAD mechanical 2007, it says "invalid object selected". I'm using a small enough radius for the part size so that's not the problem. I'm trying to fillet the solid the same way I did with AutoCAD 14, which worked great.
I've looked in the file menu of AutoCAD Mechanical and I cannot seem to find a way to fillet the solid. I also created a 3D solid model box and tried to filled one corner, just to make sure that it's not the particular solid I'm working with. The fillet command would not work on the solid model box either.
When I open the drawing in Regular AutoCAD 2007 (not mechanical), the fillet command works fine on the solid.
Is there another way to fillet the corner of a 3D solid in AutoCAD Mechanical ? If this is actually how the program works, it seems ridiculous to me to have the ability to fillet 3D solids in regular AutoCAD but not AutoCAD mechanical. I'm hoping I'm missing something.
Any advice or suggestions would be appreciated.
John
John
