nkwheelguy,
thanks for the detailed instructions. I'm using NX1.0.3.2.... I am, however, able to find the boundary command!! The Remove Hole is not allowed, and the Remove Trim works, but a little more than i would like.
I'm not sure I understand about the Insert->Trim->Trimmed Sheet instructions. I've found the command but no luck using it...
did i mention, "working with 'dumb' solids is never fun!"?
Patrick McCracken
CNC Programmer
