FileSystemObject: textfile contents erased
zimGirl
Geotechnical
Jul 22, 2004
30
Code:
Set fs = CreateObject("Scripting.FileSystemObject")
        Set f = fs.GetFile(dlgMain.FileName)
        Set a = f.OpenAsTextStream(varFileNum)
Hey guys,
When I open a file as a textstream (Code above) and hit the (X) to close the form and
exit program before using it in the program (Not Graceful exit), It erases the text
in the file and I get a blank file left over. (same name)
Is there something I am not doing at the end. Why does it erase the text in the file?
Are you closing the document first?
"Everybody is ignorant, only on different subjects." — Will Rogers
No I am not, how do I do close the document?
from your code, it would be...
a.close
hey borgunit,
Thanks for the help, worked great!!!
I had to close both the stream and the file
Code:
a.Close
Close #varFileNum
