Files being saved to their original location
  • Thread starter Thread starter toonyank
  • Start date Start date
T
toonyank
Guest
We are going back to stand alone Creo for work reasons so it's back to search paths (no more windchill)
This is not a problem in general, and all of our data is accessible with the search path declared.
The problem is and this is what I can't remember is that once I load a drawing for instance, any changes are saved locally and not to where our common data is kept (the original location).
Years ago in Pro E land we used search paths and if anything was saved, it was saved to the original location. This is what I remember. Does that make sense?
Greg
Set the config option save_object_in_current to no.
I would use both of these in config.sup:
save_object_in_current no
override_store_back no
override_store_back set to no works, thanks.
