FILE MANAGEMENT
  • Thread starter Thread starter sgorla
  • Start date Start date
S
sgorla
Guest
Hi:
I wonder if there is anyway, that i can access my network files automatically in assembly files, wtihout repetetively accessing them manually.
Let me clearly explain my problem:
I have all the part drawings in a network drive instead of local drive. When i am trying to open the assembly file,that consist of all these part drawings, i have to open each and everypart drawing manually. Its not the case with the local drive files. I can open the assembly files with a single click on assembly file without opening the part drawings.
Guess i have to work on file path..
any idea on this problem?
thanks,
sree
